ERROR
COM ERROR 8
Solution or Workaround
This error occurs while digitizing coordinates:
COM ERROR 8
Cause
This is a framing error, most likely due to differences between the configuration of the digitizer's serial port and settings in the difgorm file.
Answer
Check the digitizer settings and the CON-DIG settings to make sure they are the same as per configuration notes for your digitizer.
This error is common with the Calcomp DrawingBoard III as it alters the default configuration settings.
Article ID:000001752
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
