ERROR
ERROR: code:400, Unable to complete operation. Unable to perform query operation. Bad syntax in request.
Last Published: July 28, 2025
Error Message
When a dataset in a PostgreSQL database that is not registered with the geodatabase is published to ArcGIS Enterprise, opening the attribute table for the referenced feature layer in ArcGIS Pro and selecting the option to “show selected” records displays the following error message:
Failed to load data.
Error returned when opening a table in an unregistered dataset
Cause
When viewing the schema for the dataset, it is determined that the database-maintained, unique, not null column is defined as an identity or unique integer field, as shown in the following image.
Solution or Workaround
For a PostgreSQL database, ArcGIS requires the unique ID field to be of type serial. The error can be resolved in two ways:
  • Use the Add Auto Increment geoprocessing tool to add a database-maintained, incrementing ID field to an existing table or feature class in a PostgreSQL database. A database-maintained ID field is required for all feature classes or tables you plan to edit through a feature service.
  • Define serial as the data type for the unique, not null, database maintained field in the PostgreSQL database.
SQL to create table with serial id data type
Article ID: 000029875
Software:
  • ArcGIS Pro
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
