ERROR
Can't convert string to number: Number Null
Error Message
When using the point dispersion sample extension with a geocoded theme, the following error is returned:
"Can't convert string to number: Number Null"
Cause
There are unmatched results in your geocoded theme. These unmatched records do not have any shapes associated with them. When the extension tries to get the coordinate values for the feature it gets a Null value, and errors out of its operation.
Solution or Workaround
  1. Open the table for the geocoded theme.
  2. Select the Start editing option under the table menu.
  3. Open the query builder.
  4. Enter the following into the expression box:
    Code:
    ( [Av_status] = "U" )
  5. Click New Set.
  6. Delete those records from the table.
  7. Select the Stop editing option under the theme menu.
  8. Click yes to save your edits.
  9. Run the point dispersion extension.
Article ID:000005484
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
