ERROR
Cannot write record, disk full, ..(MX)
Solution or Workaround
Summary
Running CLEAN on a large coverage fails with this message:
Cannot write record, disk full, read only, ...(MX)
Bail out...
Clean up
Cause
Most likely, there is not enough disk space available to process the coverage.
Solution
CLEAN, BUILD, and all of the OVERLAY module commands require at least 10 to 15 times the coverage size in disk space be available for temporary processing.
Delete all the temporary files (T$ prefix) to free up disk space. Re-run the desired ARC command.
Article ID:000001646
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
