Solution or Workaround
Summary
This error occurs when running BUFFER:
Cannot write record.
Disk full?
Bad record?
Read only?
Cause
Disk space, corrupted data, or access permissions.
Solution
1. Make sure you have enough disk space. BUFFER requires about 10-15 times the coverage size for scratch processing
2. Check the integrity of your data.
3. Check DOS variables like SCRMAN. You need to have write access to the current workspace.
