ERROR
Cannot sign in to ArcGIS Enterprise Cloud Builder 10.8.1 and earlier for Microsoft Azure
First Published: January 21, 2022
Last Published: August 5, 2025
Error Message
Signing in to ArcGIS Enterprise Cloud Builder 10.8.1 and earlier for Microsoft Azure does not proceed beyond the Get Started window. No error message is returned in the application.
Cause
ArcGIS Enterprise Cloud Builder 10.8.1 and earlier for Microsoft Azure rely on Microsoft .NET Framework 4.5 or higher and, by default, use TLS versions 1.0 and 1.1. These TLS versions are no longer supported by Microsoft.
Solution or Workaround
To continue using these versions of ArcGIS Enterprise Cloud Builder for Microsoft Azure, ensure that TLS 1.2 is enabled for the operating system, and that TLS 1.2 is set as the default TLS version for .NET applications on the machine where Cloud Builder is installed.
See the Microsoft instructions for the machine’s operating system:
Article ID: 000027099
Software:
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
