ERROR
Cannot re-open SMT alias file, cannot rename ARC file
Solution or Workaround
Summary
ArcEdit fails during SAVE or QUIT with one of the following error messages:
Bailing out of ARCEDIT...
or
FATAL ERROR
Can not rename ARC file
Solution
Each INFO workspace contains an arc.dir file that can be acted on by only one user at a time. Even if two users are editing different coverages in the same workspace, if they access the arc.dir file simultaneously, a FATAL ERROR can occur. Therefore only one edit session per workspace is advised.
A second possibility is permission problems within the coverage and/or INFO directory. Check to make sure that user(s) in question have read and write permissions for all files in the coverage and INFO directories.
Article ID:000001374
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
