ERROR
Case I:
When adding a custom component (.tlb file) in ArcMap the message returned is, “No new objects added.” The methodology used for adding the component is to click Customize > Customize Mode; select the Commands tab in the Customize dialog box, and click Add From File.![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011301/00N39000003LL24-0EM39000000wdHu.png)
Case II:
When using the ESRIRegAsm utility to register a custom component (.dll) in ArcMap, the error message returned is, “Registration failed. Could not write to disk.” ![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011301/00N39000003LL24-0EM39000000wdHv.png)
This behavior occurs if the User Account Control (UAC) setting in the Windows 7 machine is set high - to, or close to, 'Always notify.'
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011301/00N39000003LL2C-0EM39000000wdHs.png)
Article ID: 000011301
Get help from ArcGIS experts
Start chatting now
