ERROR
Cannot connect to SAP HANA database because the database software client failed to load
Error Message
Attempting to register an SAP HANA database with ArcGIS Server after configuring an ODBC driver returns the error message:
Error:
Cannot connect to database because the database client software failed to load. Be sure the database client software is installed and configured correctly.
Image of the error message
Cause
This error is caused by an incorrect environment variables path.
Solution or Workaround
To resolve the problem, add the PATH system variable to the machine.
  1. Click Start on the Windows taskbar.
  2. Right-click This PC, and select Properties.
  3. Select Advanced system settings to open the System Properties window.
Image of the Advanced system settings selection
  1. Click on the Advanced tab, and select Environment Variables.
Image of the System Properties Advanced tab selection
  1. Click New to open an Edit System Variable dialog box. Fill in the fields with the following, and click OK.
Variable name: PATH
Variable value: C:\Program Files (x86)\sap\hdbclient
Image of the New System Variable dialog box
Installing the SAP HANA client without administrative rights limits the client's availability to the user who installed it. The default installation folder for this is <%USERPROFILE%>\SAP\hdbclient.
The default location for an installation with administrative rights is C:\Program Files (x86)\sap\hdbclient.
Article ID: 000021782
Software:
  • Third Party Product
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
