ERROR
On the ArcGIS Enterprise machine, attempts to run the webgisdr utility to create a backup file for the deployment fail, and return the following error message in the Command Prompt window:
Error: Cannot access the file <PropertiesFilePath>.
Depending on the cause, use one of the options below to resolve the issue.
Use quotation marks when specifying the properties file path
In the Command Prompt window, use quotation marks when specifying the properties file path with spaces. For example, a properties file path located in Program Files is specified as:
“C:\Program Files\<PropertiesFileName>.properties”
Save the properties file with the correct file extension
On the ArcGIS Enterprise machine, save the properties file with a .properties extension before running the webgisdr utility in the Command Prompt window.
Article ID: 000029217
Get help from ArcGIS experts
Start chatting now
