ERROR
Can’t use this feature layer due to an unknown error
Last Published: December 22, 2023
Error Message
When selecting a feature layer in ArcGIS QuickCapture through an ArcGIS Enterprise feature service, the following error is returned:
Error:
Please try again. If the error persists, please contact Esri Support.
The error message, Cant use this feature layer due to an unexpected error is returned.
Cause
  • The ‘Allow access to the portal through HTTPS only’ option is disabled in Portal for ArcGIS.
  • The ArcGIS URLs are blocked by the Cross-Origin Resource Sharing (CORS) policy.
  • The ArcGIS URLs are blocked in ArcGIS Enterprise.
Solution or Workaround
Depending on the cause, follow one of the workarounds below.
Enable HTTPS-only communication for the portal
Enable the Allow access to the portal through HTTPS only option in Portal for ArcGIS. Refer to Portal for ArcGIS: Configure HTTPS for further instructions.
Create URL exceptions in the organization
Contact the IT department to create URL exceptions in the organization for the following URLs:
https://www.arcgis.com
https://www.arcgis.com/apps/quickcapture
https://quickcapture.arcgis.com
Create exceptions in the ArcGIS Server settings
Only administrators are able to perform the following workaround.
  1. Log in to the ArcGIS Server Administrator Directory.
  2. Click Home > system > handlers > rest > servicesdirectory.
  3. In the Services Directory page, click edit.
  4. In the Edit Services Directory page, for the AllowedOrigins field, type the following URL.
  1. Click Save.
The Edit Services Directory configuration.
  1. Repeat Steps 3 through 5 using the following URLs.
Article ID: 000022985
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise 11 0
  • ArcGIS Enterprise 11 1
  • ArcGIS QuickCapture
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
