ERROR
Error calling unlink for file ... \delta.rcm
Error Message
This error occurs when saving edits to a theme or table:
"Error calling unlink for file <home>\delta1.rcm"
where, 'home' represents the path to the folder currently defined as ArcView's HOME directory.
Cause
When you edit a shapefile, a number of temporary delta files are created in the
HOME directory. These files are of the type .rcm or Record Map. ArcView will
produce an error message when it has problems creating or reading any of
these files; that often occurs when the hard disk has become full.
Solution or Workaround
Clean up the disk containing HOME, or change HOME to a different disk.
Article ID:000003849
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
