ERROR
This error occurs when opening a project file:"Avarray: Index 43 not in range 0..42"
The project file contains a corrupt document.
Warning:
Editing in a text editor can permanently damage a project file. If you do make a mistake, revert to the back-up copy.
/3.0
(ODB.1
FirstRootClassName: "Project"
Roots: 2
Version: 30
(Project.2
CreationDate: "Thursday, June 12, 1997 07:10:01"
GUIName: "Project"
Win: 3
CSMgr: 4
VisGUIWidth: 70
Doc: 5
Doc: 177
Doc: 143
Doc: 187
Doc: 39
ActiveDoc: 187
Buttons: 378
Buttons: 379
Buttons: 380
Dependencies: 381
Scripts: 382
WorkDir: 1178
WinX: 11
WinY: 4
WinW: 852
WinH: 594
SerialNumber: "#######"
SelColor: 1179
GUINames: 1180
GUINames: 1181
GUINames: 1182
GUINames: 1183
GUINames: 1184
GUINames: 1185
GUINames: 1186
Doc: 5
Doc: 177
Doc: 143
Doc: 187
Doc: 39
ActiveDoc: 187
Doc: 5
REM Doc: 177
REM Doc: 143
REM Doc: 187
REM Doc: 39
ArcView does not recognize REM as a valid object keyword. Therefore, ArcView will treat this line as a comment causing the document to be skipped.
Use the process of elimination until you find all the bad documents and keep as many good ones as possible.
Article ID:000003806
Get help from ArcGIS experts
Download the Esri Support App
