ERROR
Automation error when setting up Geocoder
Error Message
When attempting to set the StandardizingRules property of the Standardizer, the following error message is received:Automation Error: The object invoked has disconnected from its clients.
Cause
One or more required support files are missing from the directory containing the StandardizingRules file.
Solution or Workaround
When deploying MO2 applications that use the Geocoder, make sure to include the following support files (found in the GeoRules folder):
  prefix.tbl
direct.tbl
expand.tbl
suffix.tbl
related *.cls, *.dct, and *.pat files
These files should be included in addition to the *.mat and *.stn files referenced in your code.
Also, make sure all deployed GeoRules files are installed to a single directory on the target machine.
Article ID:000001948
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
