ERROR
Assertion - Bit in range failed in line 268 ...\base\bitmap.c
Error Message
When accessing a shapefile, ArcView returns the error:"Assertion - Bit in range failed in line 268 ...\base\bitmap.c"
Cause
Shapefile's spatial index is corrupt
Solution or Workaround
  1. Make a backup copy of the shapefile. You can do this from Windows Explorer or from a Command Prompt window.
  2. Delete or rename the .sbn and .sbx file associated with the shapefile.
  3. Re-add the theme to the view.
Article ID:000002098
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
