ERROR
Area and Volume statistics on rasters ignore Z factor
Error Message
** Fixed at ArcGIS 8.2 **The Z Factor property listed on the Area and Volume statistics is ignored in the calculation when the input surface is a raster.
Cause
This is a known issue.
Solution or Workaround
You can use the ArcGIS 3D Analyst developer sample Raster Math Command to factor the surface before running Area and Volume.
Alternately, if you have ArcGIS Spatial Analyst installed, you can use the Raster Calculator to factor the surface.
    Article ID:000004737
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
