Solution or Workaround
Attempting to query on an ArcStorm library returns the following error:
Unable to open Cross-tile index for mapsection
/path/alib/tile_16/flae
No feature located
Answer:
This error with 'Unable to open Cross-tile index for mapsection' is related to the OBJECT__ID date stamp.
If cross tile indexes are lost, the item must be manually re-indexed.
1. All feature classes of all layers should have this index. To determine if this index exists, run SCHEMAEDIT - ITEMS. For example:
SchemaEdit: items layer alib property poly
COLUMN ITEM NAME WIDTH OUTPUT TYPE N.DEC ALTERNATE NAME
INDEXED?
1 AREA 8 18 F 5 -
9 PERIMETER 8 18 F 5 -
17 PROPERTY# 4 5 B - -
21 PROPERTY-ID 4 5 B - -
25 APN 9 9 C - PARCEL_NUMBER Indexed
34 GENPLAN 3 3 C - GEN_PLAN_CODE -
37 LANDUSE 3 3 I - LANDUSE_CODE -
40 ZONING 10 10 C - ZONING_CODE -
50 LOCK__ID 4 10 B - -
54 PHASE__ID 2 5 B - -
56 OBJECT__ID 4 10 B - Indexed
** REDEFINED ITEMS **
25 BOOK 4 4 C - BOOK_NUMBER -
29 PAGE 2 2 C - BOOK_PAGE_NUMBER -
31 BLOCK 1 1 C - BLOCK_NUMBER -
32 PARCEL 2 2 C - PARCEL_NUM -
