Error Message
Opening an MXD causes ArcMap to crash and Windows returns one of the following errors:"The instruction 0x0000000 referenced memory at 0x0000000 which could not be read.Arcmap.exe has generated errors and will be closed by windows.ArcMap has encountered a problem and needs to be closed."
Cause
The print server hostname was changed and the MXD was saved with the Same as Printer check box checked in ArcMap.
![[O-Image] Pagesetup](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000006123/00N39000003LL23-0EM39000000wcl1.png)
Solution or Workaround
The MXD needs to be edited to include the new printer. The MXD Doctor utility allows a new printer to be selected. This utility requires that the ArcObjects Developer Kit be installed.
- Load a blank MXD into ArcMap.
- Click ArcObjects Online and select 'Utilities > How to set up the MXD Doctor and MXD Defragmentor Utilities'. Follow setup instructions provided.
- Click ArcObjects Online and select 'Utilities > MXD Doctor'. Follow instructions provided to load the MXD.
- Click the 'Printer Setup...' button in the lower left hand corner of the dialog box and browse to the new printer.
![[O-Image] mxddoctor](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000006123/00N39000003LL2C-0EM39000000wckz.png)
- Select the Treatment tab and click the 'Fix Document' button on the bottom of the dialog box.
![[O-Image] treatment](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000006123/00N39000003LL2C-0EM39000000wcky.png)
By default, all of the features of the problem MXD are copied to the blank MXD loaded in step 1. - Save the MXD with the new printer.
