ERROR
ArcGIS Survey123: Unable to create a new survey. Create Service exception 'Unexpected: no hosting server available'
First Published: January 16, 2024
Last Published: March 27, 2026
Error Message
In ArcGIS Survey123, attempting to create a survey using ArcGIS Enterprise credentials fails and returns the following error message:
Error:
Unable to create a new survey. Create Service exception 'Unexpected: no hosting server available.'
The error message returned in ArcGIS Survey123.
Cause
Portal for ArcGIS is not configured with a hosting server and a relational data store. When creating a survey in ArcGIS Survey123, a folder containing a form item, a hosted feature layer, and a web map are created and published to Portal for ArcGIS. A hosting server must be registered in Portal for ArcGIS to allow this.
Solution or Workaround
Configure a hosting server and register the hosting server in Portal for ArcGIS. Refer to Portal for ArcGIS: Configure a hosting server for instructions.
List of server sites in Portal for ArcGIS.
If the error persists even if a hosting server is configured, ensure the server site is running.
  1. In the ArcGIS Enterprise site, navigate to Organization > Settings > Servers.
  2. Click Validate server sites.
If the server site fails to validate, ensure the ArcGIS Server service is running on Windows. On the server machine, navigate to Control Panel > System and Security > Windows Tools. Double-click Services.
  1. If the Portal for ArcGIS service is not running, right-click the service and click Start.
  2. If the Portal for ArcGIS service is running, right-click the service and click Restart.
Article ID: 000031732
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
  • ArcGIS Survey123
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
