ERROR
ArcGIS Survey123: Initializing form... TypeError: o.split is not a function
First Published: September 30, 2026
Last Published: September 30, 2026
Error Message
A survey is successfully published from ArcGIS Survey123 Connect to ArcGIS Online. However, when the published survey is opened in a web browser, the form returns the following error:
Error:
Error: Initializing form…
The error message
Cause
The error message is returned when an invalid expression or value is specified in the constraint column. This can occur when:
  • A text question type is configured with a numeric value, such as '5', in the constraint column.
  • The maximum number of characters allowed for a text response is specified in the constraint column instead of the bind::esri:fieldLength column.
Solution or Workaround
Depending on the cause, the workarounds provided are applicable.
Use a valid constant expression
  1. In ArcGIS Survey123 Connect, open the survey’s XLSForm.
  2. In the survey worksheet, locate the row containing the invalid value in the constraint column.
  3. In the type column, select the appropriate question type from the drop-down list. In this example, integer is selected.
  4. In the constraint column, specify a valid constraint expression. The constraint must contain an expression that allows Survey123 to evaluate and validate the response. Refer to ArcGIS Survey123: Constraints for more information. In this example, regex(., '^\d{5}$') is used to require the response to contain exactly five digits.
The question type configuration
  1. Save and close the XLSForm.
  2. In the survey window, click Publish to republish the survey.
Specify the maximum number of characters in the bind::esri:fieldLength column
  2. In the survey worksheet, locate the row of the text question and remove the numeric value from the constraint column.
  3. Scroll right to the bind::esri:fieldLength column and specify the preferred maximum number of characters.
  4. Save and close the XLSForm.
  5. In the survey window, click Publish to republish the survey.
Article ID: 000043477
Software:
  • ArcGIS Online
  • ArcGIS Survey123 Connect
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
