ERROR
In a multi-machine ArcGIS Enterprise environment, the automated backup of ArcGIS Server with the Web GIS Disaster Recovery (WebGISDR) tool fails, returning the following error message in the WebGISDR log:
Error:
Failed to back up the ArcGIS Server:
Url: <URL_Path>.
{"code"500,"messages":["Export services operation failed. A JSONObject text must begin with "{" at character 1 of \u0000\u0000\u0000\....\u0000"],"status":"error"}
The ArcGIS Server logs reveal the following severe error message:
Error:
Webhook log: Error in Webhook Processor. init WebhookProcessors failed. Gerring WebhookProcessorsConfig failed A JSONObject text must begin with '{' at character 1 of
The webhookprocessors-config.json file is corrupted. The root cause is likely due to insufficient storage space being during the WebGISDR backup process.
The default file path directory of the webhookprocessors-config.json file is:
C:\arcgisserver\config-store\system\webhookprocessors-config
If webhooks have not been previously configured on the deployment, refer to the following workflow:
The image below illustrates an example of the webhookprocessors-config.json file after completing the workflow.
If webhooks have been previously configured on the deployment, refer to the following workflow:
Note: For best practice, ensure sufficient storage is available for future ArcGIS Server backups to prevent this issue from recurring. Refer to Portal for ArcGIS: Manage ArcGIS Data Store backups for additional information.
Article ID: 000033352
Get help from ArcGIS experts
Start chatting now
