ERROR
In ArcGIS Pro, attempts to apply, change, rename, or reorder symbology in the Symbology pane fail and return the following generic error message:
Error: Requested operation could not be completed.
Although this message seems generic, it only occurs in the Symbology pane and is specific to ArcGIS Pro symbology workflows.
The simplest solution is to close and re-open the Symbology pane. However if this does not resolve the issue, use one of the options below, depending on the cause.
Note: If the issue persists, contact Esri Technical Support.
Article ID: 000029255
Get help from ArcGIS experts
Start chatting now
