ERROR
ArcGIS Pro: No ArcSDE server license found or SDE run-time license has expired
First Published: November 28, 2023
Last Published: March 13, 2026
Error Message
Attempts to connect to an existing database connection in ArcGIS Pro fail and return the following error:
Error:
No ArcSDE server license found or SDE run-time license has expired.
The error window when connecting to existing database connection
Cause
The keycodes file used to create the connection from ArcGIS Server is expired. The expiration date can be identified by opening the file using a text editor, for example, Notepad++, and checking the date specified in the strings provided in the file as shown in the following image:
The expiration date in the keycodes file
Solution or Workaround
To resolve the issue, generate and retrieve the new keycodes file.
  1. Retrieve the latest version of the keycodes file depending on the following scenarios:
C:\Program Files\Esri\Licenses<version>\sysgen
  1. Connect to the database. Refer to ArcGIS Pro: Connect to a database for more information.
Article ID: 000031579
Software:
  • ArcGIS Pro
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
