ERROR
ArcGIS Pro: Failure to Load Preset
First Published: September 15, 2026
Last Published: September 15, 2026
Error Message
In ArcGIS Pro, attempts to export a layout using a preset fail and the following error message is returned:
Error:
This preset file contains settings for layout export and cannot be used in a map export.
The error message
Cause
The map frame being activated causes a map export to be performed instead of a layout export, preventing the preset from being used and returning the error.
Solution or Workaround
Deactivate the map frame to export the layout using the preset. Refer to Step 4 in ArcGIS Pro: Activate a map frame for the instruction.
Article ID: 000043306
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
