ERROR
ArcGIS Pro: Failed to display the raster layer as Classify
Last Published: February 14, 2025
Error Message
When attempting to change the symbology of a raster layer to Classify in ArcGIS Pro, the layer does not render and returns the following error message:
Error:
The error message when attempting to change symbology to Classify
Cause
  • The raster dataset lacks the required statistics, preventing ArcGIS Pro from determining the range or distribution of values required for classification.
  • The 'Maximum number of unique values to display' setting for the raster dataset in ArcGIS Pro is too low.
Solution or Workaround
Depending on the cause, the following options are applicable.
Use the Calculate Statistics tool to generate statistical summaries for the raster dataset
  1. In ArcGIS Pro, navigate to the Analysis tab and click Tools.
  2. In the Geoprocessing pane, search for and select Calculate Statistics (Data Management Tools).
  3. Configure the parameters in the Calculate Statistics pane.
    1. For Input Raster Dataset, select the raster dataset from the drop-down menu.
    2. Leave the other parameters as default and click Run.
  4. Remove the raster layer from the project using the Delete tool. Alternatively, in the Contents pane, right-click the raster layer and select Remove.
  5. Re-add the raster dataset to the project. Refer to ArcGIS Pro: Add layers to a map or scene for instructions.
The Calculate Statistics tool can be automatically executed on the raster dataset each time the dataset is added to the ArcGIS Pro project. In the project, navigate to Project > Options > Raster and Imagery. Expand Raster Dataset > Calculate statistics. For Calculate Statistics dialog settings, select Always calculate statistics from the drop-down menu and click OK.
Increase the 'Maximum number of unique values to display' setting value
In ArcGIS Pro, the 'Maximum number of unique values to display' setting controls the maximum number of distinct raster values to be visualized within a single layer when applying symbology types such as Unique Values or Classify. Increasing the value enhances the flexibility of visualizing datasets with larger quantities of unique values for a more detailed representation of the data. Refer to ArcGIS Pro: Raster and imagery default options for instructions and more information.
Article ID: 000034530
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 3
  • ArcGIS Pro 3 2
  • ArcGIS Pro 3 4
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
