ERROR
ArcGIS Pro: Failed to connect to the specified DBMS instance
First Published: November 28, 2023
Last Published: February 24, 2026
Error Message
Attempts to establish a new database connection in ArcGIS Pro fail and the following error is returned:
Error:
Failed to connect to the specified DBMS instance. A database connection exception has occurred. A product licensing error occurred.
Connection Error message window
Cause
The keycodes file used to create the connection from ArcGIS Server is expired. The expiration date can be identified by opening the keycodes file using a text editor such as Notepad++ and checking the date specified in the strings provided in the file, as shown in Notepad++ below.
The expiration date in the keycodes file
Solution or Workaround
To resolve the issue, generate and retrieve the new keycodes file.
  1. Retrieve the latest version of the keycodes file depending on the following scenarios:
C:\Program Files\Esri\Licenses<version>\sysgen
  1. Connect to the database. Refer to ArcGIS Pro: Connections to relational databases in ArcGIS Pro for more information.
Article ID: 000031560
Software:
  • ArcGIS Pro
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
