ERROR
ArcGIS Pro ERROR code 400, Unable to delete item. This service item has a related Service item. Bad syntax in request
Last Published: February 27, 2024
Error Message
When attempting to overwrite an ArcGIS Online hosted feature layer in ArcGIS Pro, the following error message is returned:
Error:
Failed to publish web layer
The Failed to publish web layer error message
Accessing the log by clicking View log displays the following error log:
Error:
ERROR: code:400, Unable to delete item. This service item has a related Service item, Bad syntax in request.
The error message ERROR: code:400, Unable to delete item. This service item has a related Service item, Bad syntax in request. in the ArcGIS Pro SharingJobLog log
Cause
The hosted feature layer has a hosted feature layer view with joins created using the Join Features tool in Map Viewer. Feature layers that include in view layers with joins cannot have their schema altered and are always read-only. Therefore, the feature layer cannot be overwritten.
Solution or Workaround
Before overwriting the ArcGIS Online hosted feature layer in ArcGIS Pro, delete the hosted feature layer view created from the Join Features tool. Refer to ArcGIS Online: Delete a single item for instructions to delete the hosted feature layer view.
The Delete Item on the hosted feature layer view Settings page
Article ID: 000031972
Software:
  • ArcGIS Online
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
