ERROR
ArcGIS Pro ERROR code 400, Unable to delete item. Delete protection is turned on. Bad syntax in request
First Published: September 7, 2021
Last Published: February 28, 2024
Error Message
When attempting to overwrite an ArcGIS Online hosted feature layer in ArcGIS Pro, the following error message is returned:
Error:
Failed to publish web layer
The Failed to publish web layer error message in ArcGIS Pro
Accessing the View log shows the following error:
Error:
ERROR: code:400, Unable to delete item <Item ID>. Delete protection is turned on., Bad syntax in request.
The error message ERROR code:400, Unable to delete item <Item ID>. Delete protection is turned on., Bad syntax in request. in the error log
Cause
The hosted feature layer has the delete protection setting enabled.
Solution or Workaround
Before overwriting the ArcGIS Online hosted feature layer in ArcGIS Pro, disable the delete protection setting.
  1. In ArcGIS Online, navigate to Content > My Content, browse to and click the hosted feature layer to open the item details page.
  2. On the item details page, click the Settings tab.
  3. Under the Delete Protection section, uncheck the Prevent this item from being accidentally deleted check box.
  4. Click Save.
The Prevent this item from being accidentally deleted check box
Article ID: 000026371
Software:
  • ArcGIS Pro
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
