ERROR
ArcGIS Pro: ERROR: code:400, Unable to delete item
First Published: February 27, 2024
Last Published: April 2, 2026
Error Message
When attempting to overwrite an ArcGIS Online hosted feature layer in ArcGIS Pro, the following error message is returned:
Error:
Failed to publish web layer
The Failed to publish web layer error message
Accessing the log by clicking View log displays the following error log:
Error:
ERROR: code:400, Unable to delete item. This service item has a related Service item, Bad syntax in request.
The error message ERROR: code:400, Unable to delete item. This service item has a related Service item, Bad syntax in request. in the ArcGIS Pro SharingJobLog log
Cause
The hosted feature layer has a joined hosted feature layer view created directly from the feature layer’s item page, as well as view layers with 'Areas of interest' defined within them. Feature layers included in view layers with joins cannot have their schemas altered and are always read-only. Therefore, the feature layer cannot be overwritten.
Solution or Workaround
Before overwriting the ArcGIS Online hosted feature layer in ArcGIS Pro, delete the joined hosted feature layer view. Refer to ArcGIS Online: Delete a single item for instructions.
The Delete item option on the hosted feature layer view Settings page
Article ID: 000031972
Software:
  • ArcGIS Pro
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
