ERROR
In some instances, performing edits or utilizing a geoprocessing tool on a service fails and returns the following error message:
Error: Edit operation failed. ERROR: code:500, Error handling schema request: java.lang.Exception: java.io.IOException: Server object extension '<Service_Capability>server' not found., Internal server error.
The error message may vary depending on the listed service capabilities. For example, if the Validation capability is not selected, the process fails and returns the following error message:
Error: Edit operation failed. ERROR: code:500, Error handling schema request: java.lang.Exception: java.io.IOException: Server object extension 'validationserver' not found., Internal server error.
This error occurs in ArcGIS Pro, ArcGIS Field Maps, and in the ArcGIS Server logs.
Note: This issue occurs in ArcGIS Pro versions prior to 3.4 and is resolved with the implementation of ENH-000137900.
The service capability check box is unchecked in ArcGIS Server Manager.
Despite the error message stating "Server object extension," the error does not correlate to the server object extension (SOE) or any .soe files created by the extension developer in ArcGIS Server Manager.
Note: The following workflow does not apply to the Version Management capability due to a known defect, BUG-000139575.
Article ID: 000035176
Get help from ArcGIS experts
Start chatting now
