ERROR
ArcGIS Pro: Database Connection: Underlying DBMS error [unknown error. No extended error.]
First Published: December 18, 2025
Last Published: April 21, 2026
Error Message
In ArcGIS Pro, creating a database connection to a SQL Server database fails and returns the following error message:
Error:
The error message
Cause
  • The Microsoft Open Database Connectivity (ODBC) driver for SQL Server is not installed on the machine to make a connection to SQL Server.
  • The installed ODBC driver is incompatible with the SQL Server version. Refer to Microsoft: Release life cycles for more information.
Solution or Workaround
Install a compatible ODBC driver for SQL Server on the machine. Refer to ArcGIS Pro: Install the ODBC driver for SQL Server and ArcGIS Enterprise: Software required to connect to SQL Server for more information.
If the issue persists, verify whether multiple ODBC driver versions are installed on the machine. If more than one version is installed, uninstall the incompatible ODBC driver. Refer to Microsoft: Using Device Manager to uninstall devices and driver packages for instructions.
Article ID: 000039635
Software:
  • ArcGIS Pro
  • ArcGIS Enterprise
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
