ERROR
In some instances, when attempting to upgrade an enterprise geodatabase created with SQL Server, the process fails and returns the following error:
Error: Executing: UpgradeGDB "<Geodatabase_Name>" PREREQUISITE_CHECK UPGRADE Start Time: <Day_Month_Date> <Hours_Minutes_Seconds> <Year> Paused the database for upgrade. There are no active connections. User has privileges required to upgrade. Running Pre-Requisite check (C:\Users\<USERNAME>\AppData\Roaming\ESRI\ArcGISPro\<.sde_file_path>). Instance supports XML type. Updating server tables and stored procedures. Successfully enabled database option ALLOW_SNAPSHOT_ISOLATION and READ_COMMITTED_SNAPSHOT. Could not update server tables and stored procedures. (Error (-37) ) Refer to upgrade logfiles for more details: C:\Users\<USERNAME>\AppData\Local\Esri\ArcGISPro\GDBUpgrade.log C:\Users\<USERNAME>\AppData\Local\Temp\10\sde_setup.log Unpaused the database. ERROR 001841: The class was not found%s. Failed to execute (UpgradeGDB). Failed at <Day_Month_Year> <Hours_Minutes_Seconds> (Elapsed Time: <Duration>)
Warning: Esri recommends creating a full backup of the geodatabase before proceeding with the upgrade. This precaution helps prevent data loss and allows restoration of the geodatabase in case of any issues during the upgrade process.
Note: In an enterprise geodatabase, the geodatabase administrator user type is also known as the Spatial Database Engine (SDE) user type, and only the SDE user type can upgrade the enterprise geodatabase. However, in SQL Server, if an SDE user type is not assigned, the upgrade can be performed by a database owner (dbo) schema user.
Upgrade the enterprise geodatabase with the necessary permissions. Refer to ArcGIS Pro: Upgrade an enterprise geodatabase in SQL Server for additional information.
Article ID: 000033391
Get help from ArcGIS experts
Start chatting now
