ERROR
ArcGIS Pro: 003341 This operation is not supported on Esri Spatial Types
Last Published: June 17, 2025
Error Message
The attempt to run the Check Geometry and Repair Geometry tools in ArcGIS Pro on a registered feature class fails and returns the following error:
Error:
ERROR 003341 This operation is not supported on Esri Spatial Types.
The error message
Cause
The data type used for the tools does not match the database connection. For example, if an SDO_Geometry spatial type is used with an Oracle database connection without the required SDO_Geometry library installed or properly configured, the tool does not function as expected.
Solution or Workaround
Use a compatible database connection
Ensure the database connection is configured correctly for the spatial type by configuring the appropriate settings and verifying compatibility. Refer to ArcGIS Pro: Check Geometry and ArcGIS Pro: Repair Geometry for more information.
Export the data to a local file geodatabase
Export the data to a local file geodatabase to maintain compatibility and avoid spatial type restrictions. Refer to How To: Export a feature service to a file geodatabase feature class in ArcGIS Pro for instructions.
Article ID: 000035056
Software:
  • ArcGIS Pro
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
