ERROR
ArcGIS Online and Portal for ArcGIS: This group is protected and cannot be deleted
First Published: May 4, 2023
Last Published: April 20, 2026
Error Message
In ArcGIS Online or the ArcGIS Enterprise portal, attempts to delete a group fail with the following error:
Error:
This group is protected and cannot be deleted.
An error message is returned when attempting to delete a group in ArcGIS Online or Portal for ArcGIS.
Cause
The 'Deletion management' setting is enabled in the group setting. In some instances, the 'Deletion management' setting cannot be disabled when the group is linked to a distributed collaboration.
Solution or Workaround
Follow the instructions below to disable the group's Deletion management setting.
For distributed collaboration groups, delete the collaboration or the collaboration workspace linked to the group before performing the workflow below.
  1. In ArcGIS Online or the ArcGIS Enterprise portal, click Groups. Browse to and click the name of the group to open the group's item page.
  2. On the item page, click Settings.
  3. Under Deletion management, disable the Prevent this group from being accidentally deleted option.
Disable the Delete management setting to delete the group.
Article ID: 000030300
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
