ERROR
When attempting to register ArcGIS Data Store with ArcGIS Monitor, the process fails and returns the following error message:
Error: The server does not support SSL connections
This error can occur when registering ArcGIS Data Store with a newly installed ArcGIS Monitor or after upgrading ArcGIS Monitor.
Use the replacesslcertificate utility in ArcGIS Data Store to replace the missing or improperly configured certificates with valid certificates. Refer to ArcGIS Enterprise: Replace ArcGIS Data Store SSL certificates for instructions.
Use the changedbproperties utility in ArcGIS Data Store to set the enablessl parameter to true. The following is an example of the syntax used with the changedbproperties utility:
changedbproperties --store <relational/tileCache> --enablessl true
For more information, refer to Portal for ArcGIS: changedbproperties.
Article ID: 000035744
Get help from ArcGIS experts
Start chatting now
