ERROR
ArcGIS Monitor: Initial user required to login. Contact your administrator
Last Published: May 27, 2025
Error Message
After installing ArcGIS Monitor 2024.x and attempting to login in a web browser, the following error is returned:
Error:
An initial user is required to login. Please contact your administrator.
The error message
Cause
In ArcGIS Monitor 2024.x, the post-installation workflow has changed from previous versions (2023.x). The initial administrator setup and repository database connection must now be configured using the new command-line interface, replacing the browser-based configuration used in earlier versions. This change applies only to fresh installations of 2024.x, as upgraded environments retain existing user configurations from 2023.x.
Solution or Workaround
This workflow is required for fresh installations of ArcGIS Monitor 2024.x and replaces the browser-based configuration used in ArcGIS Monitor 2023.x.
Create the initial administrator and establish the database connection. Refer to ArcGIS Monitor: Set up ArcGIS Monitor for instructions. Once completed, access the standard ArcGIS Monitor interface to create additional users.
Article ID: 000035988
Software:
  • ArcGIS Monitor Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
