ERROR
ArcGIS for Power BI: Can't display this visual
Last Published: May 22, 2024
Error Message
In ArcGIS for Power BI, when attempting to load a spreadsheet with latitudes and longitudes, the following error is returned:
Error:
Can't display this visual.
The Latitude bucket doesn't support measures or aggregated numbers.
The Can't display this visual error is returned.
Cause
  • The ArcGIS for Power BI URLs are blocked in ArcGIS Enterprise.
  • The ArcGIS for Power BI URLs are blocked by the organization's Cross-Origin Resource Sharing (CORS) policy.
Solution or Workaround
Add the ArcGIS for Power BI URLs in ArcGIS Enterprise
Create exceptions in Portal for ArcGIS and ArcGIS Server. Refer to ArcGIS for Microsoft 365: Configure ArcGIS Enterprise cross-origin resource sharing for further instructions.
The Allow Origins parameter in ArcGIS Portal Administrator
Create exceptions in the organization's Cross-Origin Resource Sharing (CORS) policy
Contact the IT department to create URL exceptions in the organization. Refer to ArcGIS for Microsoft 365: ArcGIS for Power BI secure networks for the URL exceptions.
ArcGIS Online has certain domain requirements that must also be met. Suppose an organization decides to leverage its enterprise deployments with features like geocoding, ArcGIS Living Atlas, basemaps, imagery, demographics, infrastructure, and environmental data. In that case, ensure the network can access these additional domains.
If an organization's security policy disallows wildcards, refer to PDF: Domain Requirements for ArcGIS Online. Note that users must be signed in with an organizational account to view either of these documents, as they are located in the secure document section of the ArcGIS Trust Center https://trust.arcgis.com/.
Article ID: 000032440
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise 11 0
  • ArcGIS Enterprise 11 1
  • ArcGIS Enterprise 11 3
  • ArcGIS for Power BI
  • ArcGIS Enterprise 11 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
