ERROR
ArcGIS for AutoCAD setup requires Autodesk AutoCAD. Please refer to the installation notes for more information
First Published: April 18, 2022
Last Published: August 4, 2025
Error Message
In some instances, the ApplicationPlugins folder for Autodesk products is not created. When the ArcGIS for AutoCAD installer performs its checks it might present the user with the following notification:
ArcGIS for AutoCAD setup requires Autodesk AutoCAD. Please refer to the installation notes for more information.
ArcGIS for AutoCAD installation halted notification.
Cause
The folder, C:\Program Files\Autodesk\ApplicationPlugins, is not created when the Autodesk product is installed.
Solution or Workaround
Create the missing folder and rerun the ArcGIS for AutoCAD installation.
  1. Open Windows File Explorer.
  2. Navigate to C:\Program Files\Autodesk.
  3. Create the missing folder, ApplicationPlugins.
    • This action might require Administrator privileges.
  4. Run the ArcGIS for AutoCAD setup again.
Article ID: 000027537
Software:
  • ArcGIS for AutoCAD
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
