ERROR
ArcGIS Field Maps (Android): Connection error. The server you are trying to connect to is using an untrusted certificate
Last Published: March 19, 2025
Error Message
In ArcGIS Field Maps, attempts to connect to the Portal for ArcGIS client on an Android mobile device fail and return the following error message:
Error:
Connection error
The untrusted certificate error message
Cause
The Secure Sockets Layer (SSL) certificate chain is not trusted. If the SSL certificate is not trusted, ArcGIS Field Maps cannot establish a connection to ArcGIS Enterprise, resulting in the error. On iOS, the system automatically recognizes trusted certificates, requiring no additional steps. However, on Android, even if ArcGIS Server is configured with a trusted certificate, both the server and the device must have the certificate installed for the connection to work.
Solution or Workaround
Install the SSL certificate on a single Android mobile device
  1. Download the SSL certificate for the secured portal. Refer to ArcGIS Blog: Learn How to Download a SSL Certificate for a Secured Portal for instructions.
  2. Transfer the downloaded SSL certificate to the Android mobile device. For example, send the SSL certificate from the machine to the mobile device via email.
  3. Install the SSL certificate on the Android mobile device. Refer to ArcGIS Blog: Learn How to Install a SSL Certificate for a Secured Portal on a mobile device for instructions.
Import the SSL certificate on a load balancer or reverse proxy for multiple Android mobile devices
Contact the organization's IT department to implement the following workflow.
For multiple mobile devices or users, import the intermediate certificate(s) to the web server at the edge of the network path. For example, if the ArcGIS Enterprise portal is behind a load balancer or reverse proxy, ensure the intermediate certificate is available on the load balancer or reverse proxy. Additionally, if the ArcGIS Enterprise portal's web adaptor is directly exposed, import the intermediate certificate(s) into the Certificates snap-in window in Microsoft Management Console (MMC) in the local computer's Intermediate Certification Authority's store.
Article ID: 000034259
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise 11 3
  • ArcGIS Field Maps Android
  • ArcGIS Enterprise 11 2
  • ArcGIS Enterprise 11 4
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
