ERROR
ArcGIS Experience Builder: Only HTTPS is supported
First Published: February 23, 2026
Last Published: February 23, 2026
Error Message
When attempting to embed content using website URLs from the attribute field in the Embed widget, the embedded content is not displayed and the following error message is returned.
Error: Only HTTPS is supported.
The Only HTTPS is supported error
Cause
The attribute field is manually populated in the 'Embed by' text box of the Embed widget configuration pane. This causes the value to be treated as a single static string rather than a data-bound URL, bypassing data source mapping and runtime URL resolution. So the Embed widget cannot validate the resolved HTTPS URL and returns the error message.
Solution or Workaround
Select the data attribute from the Data option
  1. Open the experience in Experience Builder.
  2. Click the Embed widget to open the Embed pane.
  3. In the Embed pane, on the Content tab, configure the parameters.
    1. For Embed by, click URL.
    2. Toggle Connect to data on.
    3. Click Select data and in the Select data pane, select the preferred layer.
    4. Click Data The Data icon and in the Data attribute pane, select the field containing the URLs.
  4. Click Save The Save icon > Publish.
The experience below shows the Embed widget properly displaying the embedded image of the selected feature.
The experience includes the Embed widget displaying an image from the selected feature's URL content
The following alternatives can only be applied to display images referenced by image URLs stored in a field. URLs pointing to public websites or video content cannot be embedded and are treated as external links.
Use the Image or Feature Info widget
In Experience Builder, add the Image or Feature Info widget to the web experience and set the layer containing the image URLs as the data source.
The experience below shows the Feature Info widget properly displaying the embedded content of the selected feature.
The experience includes a Feature Info widget displaying URL content from the selected feature
Configure image URLs in pop-ups in Map Viewer
In ArcGIS Online Map Viewer, configure the pop-up by adding a new Image content and setting the field containing the image URLs as the URL parameter before publishing it to Experience Builder. Refer to ArcGIS Online: Add images for instructions. After which, toggle Enable pop-up on in the Map widget in the web experience.
The experience below shows the pop-up of the selected feature properly displayed.
The experience with the pop-up of the selected feature
Article ID: 000040131
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
