ERROR
ArcGIS Enterprise portal: The user may have been deleted or you may have entered an incorrect URL
First Published: June 10, 2024
Last Published: September 18, 2026
Error Message
Attempts to delete a member in the ArcGIS Enterprise portal fail with the following error message returned:
Error:
The user you requested cannot be found. The user may have been deleted or you may have entered an incorrect URL.
Cause
The portal index is corrupted, causing the index count for users to not match the store index count.
Solution or Workaround
Warning:
Esri recommends performing the reindex operation during system maintenance or downtime, as the operation takes some time to finish. During this time, portal content and search operations are unavailable and the index service may not respond correctly to index queries.
  1. Navigate to the Portal Administrator Directory as an administrator using the following URL:
https://<machine>.<domain>.com/webadaptor/portaladmin
  1. Navigate to System > Indexer > Index Status.
  2. If the Count in store values do not match the Count in index values for users, navigate to System > Indexer > Reindex.
  3. For Mode, select User from the drop-down list.
  4. For Format, select a response format from the drop-down list.
  5. Click Reindex.
Article ID: 000032729
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
