ERROR
ArcGIS Enterprise portal and ArcGIS Online: Test execution error. Cannot access property of null object. Verify test data
Last Published: March 28, 2025
Error Message
When running an Arcade expression in a Map Viewer pop-up, the following error is returned:
Error:
Test execution error: Execution error - Cannot access property of null object. Verify test data.
The error message
Cause
The layers are empty and do not contain any features. The function cannot be executed on an empty dataset. When a layer contains no feature, the attributes are considered missing because there are no values, not even null values.
Solution or Workaround
Add features to the affected layer. Refer to Portal for ArcGIS: Add features or ArcGIS Online: Add features for instructions. The error message can also be addressed by running an in statement within the script to isolate empty attributes. The following is a sample script:
If (IsEmpty(first(fs)) == false){
    Return firstFeature[“Shape_Length”];
else{
    return “No value found”;
Article ID: 000034988
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
