ERROR
ArcGIS Data Interoperability for Pro requires an All Users installation of ArcGIS Pro <version number>
First Published: September 15, 2022
Last Published: June 20, 2025
Error Message
When attempting to install the ArcGIS Data Interoperability extension for ArcGIS Pro, the following error message is returned:
Error:
ArcGIS Data Interoperability for Pro requires an All Users installation of ArcGIS Pro <version number>.
The error message is returned when attempting to install the ArcGIS Data Interoperability extension.
This issue only applies to ArcGIS Pro 3.2 and prior. See "What's New in ArcGIS Data Interoperability 3.3".
Cause
A per-user installation is made when installing ArcGIS Pro on the local machine before installing the ArcGIS Data Interoperability extension.
Solution or Workaround
Uninstall ArcGIS Pro from the local machine using Windows Control Panel or Windows Settings and reinstall ArcGIS Pro on the local machine. Ensure the Anyone who uses this computer (all users) option is checked in the ArcGIS Pro Setup window. Refer to ArcGIS Pro: Install ArcGIS Pro for more information.
Install ArcGIS Pro with the 'all users' option.
Article ID: 000028378
Software:
  • ArcGIS Pro
  • ArcGIS Data Interoperabilityx
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
