ERROR
Arc:connect oracle system/manager/usr/lib/dld.sl: Can't find path for shared library: libclntsh.sl.8.0
Error Message
Trying to connect to an Oracle 8i database on HP fails with the following error:"Arc: connect oracle system/manager
/usr/lib/dld.sl: No such file or directory
Server oracle, pid: 123 terminated abnormally"
Cause
The ArcInfo executable DBI_ORACLE is failing to find the Oracle library libclntsh.sl.8.0 which is located in $ORACLE_HOME/lib.
Solution or Workaround
Add $ORACLE_HOME/lib to the system variable $SHLIB_PATH.
    Article ID:000006128
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
