ERROR
arccat1.exe has generated errors and will be closed by windows
Error Message
Starting ArcCatalog generates this error:arccat1.exe has generated errors and will be closed by Windows
Cause
The arccatalog.gx and normal.gxt files are corrupted.
Solution or Workaround
-- Windows 2000:
1. Using Windows Explorer, navigate to c:\document and Settings\<your_username>\Application data\esri\arccatalog
2. Delete arccatalog.gx and normal.gxt
3. Restart ArcCatalog
-- Windows NT:
1. Using Windows Explorer, navigate to c:\Winnt\Profiles\<your_username>\Application data\esri\arcatalog
Article ID:000002150
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
