ERROR
ArcGIS Field Maps: Arcade expression is invalid
Last Published: March 21, 2024
Error Message
When collecting features in the ArcGIS Field Maps mobile app for Portal for ArcGIS using a map containing attribute rules configured in ArcGIS Pro, the following error message is returned:
Error:
Arcade expression is invalid.
ArcGIS Field Maps for Portal for ArcGIS.
Cause
The 'Exclude from application evaluation' option is disabled in ArcGIS Pro, resulting in attribute rules being evaluated locally prior to the application of edit requests to ArcGIS Enterprise. Refer to ArcGIS Pro: Exclude from application evaluation for more information.
Solution or Workaround
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, right-click the layer with the attribute rule configured.
  3. Click Data Design > Attribute Rules.
The Contents pane in ArcGIS Pro.
  1. In the Attribute Rules: <feature layer> view, click the Calculation tab.
  2. In the New Rule pane, expand the Execution node and check the Exclude from application evaluation check box.
The New Rule pane in ArcGIS Pro.
  1. On the ribbon, click the Attribute Rules tab.
  2. In the Attribute Rules group, click Save.
  3. Overwrite the web layer. Refer to ArcGIS Pro: Overwrite a web feature layer for further instructions.
Article ID: 000031719
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Enterprise 11 0
  • ArcGIS Enterprise 11 1
  • ArcGIS Pro 3 0
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
  • ArcGIS Enterprise 11 2
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
