ERROR
Arc not written due to zero length
Solution or Workaround
When trying to ADD an arc or a portion of an arc, the following error message
is returned:
Arc not written out due to zero length
Cause:
This is usually because the length of the arc being added is smaller than the
NODESNAP, WEED, GRAIN or FUZZY tolerances.
Answer:
In ArcEdit 'STATUS TOLERANCE' can be used to check the NODESNAP, WEED and GRAIN tolerances. At the ARC prompt 'TOLERANCE LIST' will show NODESNAP, WEED,GRAIN and FUZZY tolerances
To change tolerances:
ARCEDIT: NODESNAP {DEFAULT | * | distance}
ARCEDIT: WEEDTOLERANCE {* | DEFAULT | distance}
ARCEDIT: GRAIN {* | DEFAULT | distance}
or
ARC: TOLERANCE NODESNAP {tol_value}
ARC: TOLERANCE WEED {tol_value}
ARC: TOLERANCE GRAIN {tol_value}
ARC: TOLERANCE FUZZY {tol_value}
Article ID:000001322
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
