ERROR
AppESRIPrintLocal.EXE has encounters a problem and needs to close
Error Message
While trying to print with ArcPress, the following error may be returned:
"AppESRIPrintLocal.EXE has encounters a problem and needs to close."
Cause
The current user does not have read/write access to C:\Windows\System32\Spool\PRINTERS. In some cases, the AppESRIPrintLocal.EXE file also needs to be registered.
Solution or Workaround
Full rights to C:\Windows\System32\Spool\PRINTERS need to be granted by the System Administrator. The file AppESRIPrintLocal.EXE may also need to be registered.
  1. As the System Administrator, navigate to C:\Windows\System32\Spool\, right-click on PRINTERS and select Properties. Select the Security tab.
  2. Add the user and give the user full permissions to the PRINTERS folder.
    Contact the System Administrator if there are difficulties setting permissions.
  3. If the above error is still returned, navigate to Start > Run, type the following, and click OK:
    Code:
    <ArcGIS_install_location>\appesriprintlocal.exe /regserver
    For example: C:\ArcGIS\bin\appesriprintlocal.exe /regserver
    If ArcGIS has been installed to C:\Programs Files\ArcGIS, this command may fail. Open an MS-DOS prompt, change the directory to the ArcGIS\bin install location and run 'appesriprintlocal.exe /regserver'.
Article ID:000008070
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
