ERROR
The COGO Cul-de-sac command returns the following error:
"An unexpected failure occurred. The row contains a bad value [LAYER]. The row contains a bad value [Direction]."
This is due to one or more fields in the attribute table not large enough to contain the data the Cul-de-sac command is attempting to enter.
Reduce the number of decimals used for Display Angles in Editor > Options > Units tab.
Article ID:000010924
Get help from ArcGIS experts
Download the Esri Support App
