ERROR
An unexpected error occurred while unpacking files in ArcGIS Pro. Error code -6
Last Published: February 14, 2024
Error Message
When attempting to install ArcGIS Pro, the installation fails and the following error message is returned:
Error:
An unexpected error occurred while unpacking file(s). Error code: -6
Error code -6
The following is a non-exhaustive list of products that return the error message:
  • ArcGIS Pro
  • ArcGIS License Manager
  • ArcMap
Cause
  • The account installing the software does not have read and write permissions for the specified installation folder.
  • Windows firewall is preventing the installation.
Solution or Workaround
The following workarounds may require a Windows administrative account.
Assign read and write permissions to the account installing ArcGIS Pro
  1. Right-click the installation destination folder and select Properties.
  2. In the <folder_name> Properties dialog box, select the Security tab.
  3. Under Group or user names, click Edit....
  4. In the Permission for <folder_name> dialog box, select the username or group performing the software installation.
  5. Under Permissions for <user_name>, uncheck the Read and Write check boxes in the Deny column.
  6. Click Apply.
  7. Click OK to close the Permissions for <user_name> and <folder_name> Properties dialog box.
Permissions and properties dialog boxes
Alternatively, create a new folder or select a different folder as the installation destination folder.
Temporarily disable Microsoft Defender Firewall
  1. Disable Microsoft Defender Firewall. Refer to Microsoft: Turn Microsoft Defender Firewall on or off for instructions.
  2. Proceed with installing the software.
  3. Enable Microsoft Defender Firewall. Refer to Microsoft: Turn Microsoft Defender Firewall on or off for instructions.
Article ID: 000031880
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
